NetApp Stage KB
cluster acquistion taking longtime and intermittently polling in "failed" state
2
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
Active IQ Unified Manager 9.12(AIQUM) virtual applicance
Issue
  • ONTAP Cluster acquistion taking longtime and intermittent cluster polling status shows "failed"
  • Error in ocumserver.log can be found for cluster
ERROR [oncommand] [reconciliation-0] [<cluster>(baseline@04:00:00.001)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error
org.springframework.dao.PessimisticLockingFailureException: could not execute batch; SQL [update Event set acknowledgedBy=?, acknowledgedTimestamp=?, assignedTimestamp=?, assignedTo=?, cluster_id=?, clusterNode_id=?, encodedArguments=?, impactArea=?, isChecked=?, isContinuous=?, lastObservedTime=?, maintenance=?, notesCount=?, objVersion=?, obsoleteCause=?, obsoleteCauseEncodedArguments=?, obsoleteCauseEvent_id=?, obsoleteCauseValue_id=?, obsoleteTimestamp=?, resolvedBy=?, resolvedTimestamp=?, source_id=?, source_type=?, source_fullName=?, source_resourceKey=?, source_resourceType=?, state=?, subType=?, targetId=?, targetType=?, thresholdPolicyId=?, eventTimestamp=?, uuid=?, value_id=?, vserver_id=? where id=? and objVersion=?]; nested exception is org.hibernate.PessimisticLockException: could not execute batch
    at deployment.dfm-app.war//org.springframework.orm.hibernate5.SessionFactoryUtils.convertHibernateAccessException(SessionFactoryUtils.java:207)
    at deployment.dfm-app.war//org.springframework.orm.hibernate5.SessionFactoryUtils.flush(SessionFactoryUtils.java:120)
Caused by: org.hibernate.PessimisticLockException: could not execute batch
    at deployment.dfm-app.war//org.hibernate.dialect.MySQLDialect$3.convert(MySQLDialect.java:547)
    at deployment.dfm-app.war//org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:37)
    ... 15 common frames omitted
Caused by: java.sql.BatchUpdateException: (conn=43296) Lock wait timeout exceeded; try restarting transaction
    at org.mariadb//org.mariadb.jdbc.MariaDbStatement.executeBatchExceptionEpilogue(MariaDbStatement.java:323)
    at org.mariadb//org.mariadb.jdbc.ClientSidePreparedStatement.executeBatch(ClientSidePreparedStatement.java:301)
    at deployment.dfm-app.war//com.zaxxer.hikari.pool.ProxyStatement.executeBatch(ProxyStatement.java:131)
    at deployment.dfm-app.war//com.zaxxer.hikari.pool.HikariProxyPreparedStatement.executeBatch(HikariProxyPreparedStatement.java)
    at deployment.dfm-app.war//org.hibernate.engine.jdbc.batch.internal.BatchingBatch.performExecution(BatchingBatch.java:125)
    ... 28 common frames omitted
Caused by: java.sql.SQLTransientConnectionException: (conn=43296) Lock wait timeout exceeded; try restarting transaction
    at org.mariadb//org.mariadb.jdbc.internal.util.exceptions.ExceptionFactory.createException(ExceptionFactory.java:79)
    at org.mariadb//org.mariadb.jdbc.internal.util.exceptions.ExceptionFactory.create(ExceptionFactory.java:153)
    at org.mariadb//org.mariadb.jdbc.MariaDbStatement.executeBatchExceptionEpilogue(MariaDbStatement.java:319)
    ... 32 common frames omitted
New to NetApp?
