NetApp Stage KB
DIMM panic after replacement of DIMM and Motherboard
2
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS
  • AFF
  • ONTAP 9
Issue
  • Node encounters a DIMM panic and the DIMM is replaced.
  • Node encounters DIMM panic against the same DIMM slot and the motherboard is replaced.
  • Node encounters DIMM panic against the same DIMM slot after motherboard replacement.
New to NetApp?
