NetApp Stage KB
"CHASSIS POWER DEGRADED: Power Supply Status Critical" alerts
1
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • AFF A250, AFF C250
  • ASA A250, ASA C250
  • FAS500f
Issue
  • Node reports CHASSIS POWER SUPPLY DEGRADED and CHASSIS OVER TEMPERATURE alerts.
  • PSU sensors unreadable in the node with the issue, but not by the partner. Example:
Event logs:
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Inlet is Unreadable
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Hot is Unreadable
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 FB Hot is Unreadable
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan is Unreadable
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 In Fault is Unreadable
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Warning is Unreadable
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Out Fault is Unreadable
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Inlet is Unreadable
[n02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Hot is Unreadable
[n02: power_low_monitor: monitor.chassisPower.degraded:alert]: Chassis power is degraded: Power Supply Status Critical: PSU2, PSU1.
[n02: power_low_monitor: callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU2, PSU1.
SP-LATEST-IPMI:
PSU1_Inlet       | na         | degrees C  | na    | na        | 0.000     | 0.000     | 58.000    | 63.000    | na
PSU1_Hot         | na         | degrees C  | na    | na        | 0.000     | 0.000     | 100.000   | 105.000   | na
PSU1_FB_Hot      | na         | degrees C  | na    | na        | 0.000     | 0.000     | 100.000   | 105.000   | na
PSU1_Fan         | na         | RPM        | na    | na        | 800.000   | 1200.000  | na        | na        | na
PSU1_status      | na         | discrete   | na    | na        | na        | na        | na        | na        | na
PSU2_Inlet       | na         | degrees C  | na    | na        | 0.000     | 0.000     | 58.000    | 63.000    | na
PSU2_Hot         | na         | degrees C  | na    | na        | 0.000     | 0.000     | 100.000   | 105.000   | na
PSU2_FB_Hot      | na         | degrees C  | na    | na        | 0.000     | 0.000     | 100.000   | 105.000   | na
PSU2_Fan         | na         | RPM        | na    | na        | 800.000   | 1200.000  | na        | na        | na
PSU2_status      | na         | discrete   | na    | na        | na        | na        | na        | na        | na
New to NetApp?
