AFF A220 shuts-down with "Call home for BATTERY (no charge) CRITICAL."
Applies to
AFF-A220
Issue
AFFA220 shuts down with battery not charging alerts:
Event logs:
Console logs:
Event logs:
Record 406: Sun Apr 07 15:34:18.550000 2024 [IPMI.emergency]: env_mgr triggers OS halt:Battery not charging Record 407: Sun Apr 07 15:34:53.660000 2024 [IPMI.notice]: 01a3 | 02 | EVT: 6f03ffff | Sensor 255 | Assertion Event, "Storage OS graceful shutdown" Record 408: Sun Apr 07 15:34:55.000000 2024 [Controller.notice]: Appliance user command halt. Record 409: Sun Apr 07 15:34:53.680000 2024 [IPMI Event.critical]: System power down Record 410: Sun Apr 07 15:34:54.030000 2024 [IPMI.emergency]: Data ONTAP initiated shutdown Record 411: Sun Apr 07 15:34:54.030000 2024 [Trap Event.critical]: hwassist abnormal_reboot (28)
Console logs:
Apr 07 13:00:08 [callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL. Apr 07 13:22:59 [callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL. Apr 07 13:48:40 [callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL. Apr 07 14:09:21 [callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL. Apr 07 15:34:24 [monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery not charging)
However, sensor readings don't display Battery issues.
Bat_Temp | 24.000 | degrees C | ok | 0.000 | 5.000 | 56.000 | 60.000 Bat_Volt | 8.100 | Volts | ok | 5.500 | 5.600 | 8.500 | 8.600 Bat_Curr | 0.000 | Amps | ok | na | na | 1.520 | 1.800 Bat_Rem_Cap | 1.536 | Amps * hour | ok | na | na | na | na Bat_Full_Cap | 1.536 | Amps * hour | ok | na | na | na | na Bat_Charge_Curr | 1.000 | Amps | ok | na | na | 2.400 | 2.900 Bat_Charge_Volt | 8.200 | Volts | ok | na | na | 8.900 | 9.000 Bat_Design_Cap | 2.100 | Amps * hour | ok | na | na | na | na Bat_Initial_Fcc | 1.700 | Amps * hour | ok | na | na | na | na Bat_Average_Temp | 24.000 | degrees C | ok | na | na | na | na Bat_Rem_Cap_off | 0.120 | Amps * hour | ok | na | na | na | na Bat_Dstg_Cycles | 51.000 | cycles | ok | 2.000 | 5.000 | na | na
