NetApp Stage KB
System Manager SAML Authentication Resolution Guide
9
Visibility:
Votes:
0
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP System Manager 9.3 and later
  • Security Assertion Markup Language (SAML)
This KB article provides information on troubleshooting SAML authentication issues.
Procedure
Setup and Configure
Understanding the SAML authentication workflow
Pre-requisites for enabling SAML authentication in ONTAP System Manager
Configuring SAML authentication in Ontap System Manager in 9.7 and older
Configuring SAML authentication in ONTAP System Manager in 9.8 and newer
How to determine if SAML authentication is successful
Logs related to SAML authentication in ONTAP System Manager
How to configure SAML authentication between ONTAP System Manager and Ping Federation IdP
Multifactor authentication in ONTAP 9 Best practices and implementation guide
How to use domain group in ONTAP System Manager SAML Authentication with Entra ID as IDP
How to set up SAML authentication with Azure
Troubleshooting
Configuration of SAML authentication fails with ‘invalid host’ error
SAML authentication fails with login issues
SAML authentication fails due to missing IDP claim rule
SAML authentication fails due to missing name identifier claim rule
Unable to disable SAML from CLI
Unable to login to System Manager due to misconfigured SAML
SAML authentication is rejected due to metadata mismatch
ONTAP SAML configuration cannot be completed when the Federation IdP requires the ONTAP metadata first
When SAML is enabled the connection to System Manager is not secure
ONTAP System Manager displays IP address instead of Cluster name in browser URL
SAML authentication is failing due to ONTAP certificate expired
SAML service provider did not identify the user that was authenticated in ONTAP System Manager
New to NetApp?
