NetApp Stage KB
Chassis part number is missing in SANtricity after chassis replacement
3
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
E-Series
StorageGRID
Issue
After performing a chassis replacement during maintenance, it is noticed in the SANtricity GUI when navigating to 'Support' from the left pane-> and hovering over 'Support Center' that the chassis part number is no longer reported.
Pre-chassis replacement: Post-chassis replacement:
Note: This above example is for illustrative purposes only; in a true scenario the chassis serial number will update to reflect the new hardware in use, unlike above.
New to NetApp?
