NetApp Stage KB
E-Series detects Controller redundancy lost events due to maintenance offline
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • E-Series
  • SANtricity OS
Issue
  • E-Series system detects following events
    • E-Series Notification (Controller redundancy lost) CRITICAL
    • E-Series Notification (Write-back caching forcibly disabled) CRITICAL
  • STORAGE-ARRAY-PROFILE indicates the one controller is in Failed (Offline) status
      Controller in Shelf 99, Bay B - Unable to retrieve latest data; using last known state.
         Status:                       Failed (Offline)
  • MAJOR-EVENT-LOG indicates Controller reset by its alternate
Sequence number: 1403
Event type: 400F
Event category: Internal
Priority: Informational
Event needs attention: false
Event send alert: false
Event visibility: true
Description: Controller reset by its alternate
Event specific codes: 0/0/0
Component type: Controller
Component location: Shelf 99, Bay B
Logged by: Controller in bay A
  • No related error causes offline can be found
New to NetApp?
