NetApp Stage KB
SQL AG transaction log backups only run on one node
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
SnapCenter Plug-in for SQL (SCSQL) 4.4 and higher
Issue
Using the AG to run separate transaction log backups, only the primary replica node is backing up the transaction logs.
The secondary replica node is not running any operations.
Checking the logs from the Job as a ZIP Download from the Job History, the secondary replica node is not visible.
New to NetApp?
