NetApp Stage KB
Can we improve Wafliron performance?
2
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • Wafliron
Answer
WARNING: Manually increasing the WAFL scan speed value to a high value can cause a significant performance impact to data production.  Only change it with the direction of NetApp Technical Support.
WAFL scan speed:
  • Controlled by the nodeshell command wafl scan speed
  • By default, is automatically tuned by ONTAP based on available system resources.
  • Affects the CPU time allocated for file system scanning.
  • Higher values will negatively impact performance.
  • Does not impact Phase 1 mounting time.
Changing WAFL scan speed
  1. Check current speed if desired:
::> set advanced
::*> run local wafl scan speed
WAFL scan speed is 1300
  1. Set speed to 2000 and monitor:
::> set advanced
::*> run local wafl scan speed 2000
WAFL scan speed is 2000
  1. If further increases are needed, do so in increments of 5%.
  2. When Wafliron has completed, reset scan speed to automatic tuning:
::> set advanced
::*> run local wafl scan speed 0
Additional Information
additionalInformation_text
