NetApp Stage KB
The controller temperature (PCISW Die Temp) is not readable
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • AFF/FAS systems
Issue
  • The controller is unable to read the temperature sensor and reports the following events.
 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (PCISW-3 Die Temp) is not readable.
 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (PCISW-4 Die Temp) is not readable.
  • Chassis temperature is too high.. may following by the event.
  • PLATFORM SENSORS.XML section in autosupport reports the PCISW sensors as failed
Sensor Name State Current Critical Warning Warning Critical
Reading Low Low High High
PCISW-3 Die Temp failed -- C 0 C 5 C 90 C 100 C
PCISW-4 Die Temp failed -- C 0 C 5 C 90 C 100
New to NetApp?
