NetApp Stage KB
The NVRAM battery is not receiving power
1
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
AFF/FAS
Issue
  • Node goes down with the following messages in the event logs:
[env_mgr: nvram.battery.power.fault:EMERGENCY]: The NVRAM battery is not receiving power. To prevent data loss, the system will shut down in 5 minutes.
[env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery power fault)
  • Battery status showing Discharging in SP:
Status            : Discharging
Current           : -3 mA
RemainingCapacity : 4312 mAh
FullChargeCapacity: 4430 mAh
  • SP/BMC firmware is at the latest firmware.
  • NVRAM Battery replacement doesn't help.
New to NetApp?
