NetApp Stage KB
System DIMM configuration is not supported by FAS8300
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS8300
  • ONTAP 9
Issue
  • One node boot failure after ONTAP upgrade.
  • First boot of affect node :
Setting default boot image to image1...
done.
Uptime: 85d19h9m54s
HALT:  HA partner has taken over (ic) on Sat May 20 09:30:00 CST 2023
HBIOS Version: 16.7
PEI start.
CPU PEI initialization.
Wait BMC self-test result.
BMC self-test: OK.
UPI initialization.
CPU initialization.
Running full memory initialization.
MEMORY WARNING: Major Code 0x30 Minor Code 0x2d DIMM:H0
DIMM:H0 mapped out. BIOS MRC mapped out DIMM. Major Code 0x0a Minor Code 0x03
DIMM:H0 mapped out. BIOS MRC mapped out DIMM. Major Code 0x0b Minor Code 0x1
PI FLASH: Primary BIOS
PEI end.
DXE start.
USB initialization.
PCI host bridge initialization.
CSM initialization.
PCI Bus initialization start.
BDS start.
Console output devices connect.
  • The succedent booting after power cycle:
* Press Ctrl-C for Boot Menu. *
cryptomod_fips: Executing Crypto FIPS Self Tests.
cryptomod_fips: Crypto FIPS self-test: 'CPU COMPATIBILITY' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 ECB, AES-256 ECB' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 CBC, AES-256 CBC' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 GCM, AES-256 GCM' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-128 CCM' passed.
cryptomod_fips: Crypto FIPS self-test: 'CTR_DRBG' passed.
cryptomod_fips: Crypto FIPS self-test: 'KDF' passed.
cryptomod_fips: Crypto FIPS self-test: 'SHA1, SHA256, SHA512' passed.
cryptomod_fips: Crypto FIPS self-test: 'HMAC-SHA1, HMAC-SHA256, HMAC-SHA512' passed.
cryptomod_fips: Crypto FIPS self-test: 'PBKDF2' passed.
cryptomod_fips: Crypto FIPS self-test: 'AES-XTS 128, AES-XTS 256' passed.
cryptomod_fips: Crypto FIPS self-test: 'Self-integrity' passed.
Running the upgrade system
bootarg.upgrade="true"
bootarg.from.version="9.9.1P12"
bootarg.to.version="9.9.1P15"
Halting...
New to NetApp?
