NetApp Stage KB
SAS Expander has set the Chassis LED ON
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • AFF A200
  • FAS 2750
Issue
  • System fault LED is amber on both nodes.
Example:
200::*> system controller service-event show
Node             ID  Event Location                      Event Description
A200-01          1   Chassis 1                           SAS Expander has set the Chassis LED ON
A200-02          1   Chassis 1                           SAS Expander has set the Chassis LED ON
  • Module A/B Expander Temp shows failed.
Example:
A200::*> system node environment sensors show
Node Sensor                 State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
A200-01
     CPU0 Temp Margin
                      init-failed
                                        - C          -        -       0      -1
     CPU0 Core Temp        normal
                                       38 C          0        5      90     100
     PCM_Inlet_Temp        normal
                                       28 C          0        5      67      72
A200-02
     PSU2 FRU              normal
                                         GOOD
     PSU1 FRU              normal
                                         GOOD
     SP Status             normal
                                   IPMI_HB_OK
     Partner Status
                    not-available
     PSU1 Present
                    not-available
     PSU1 5V
                    not-available
                                        - mV         -        -       -       -
     PSU1 12V
                    not-available
                                        - mV         -        -       -       -
     PSU1 5V Curr
                    not-available
                                        - mA         -        -       -       -
     PSU1 12V Curr
                    not-available
                                        - mA         -        -       -       -
     PSU1 Fan 1
                    not-available
                                        - RPM        -        -       -       -
     PSU1 Fan 2
                    not-available
                                        - RPM        -        -       -       -
     PSU1 Inlet Temp
                    not-available
                                        - C          0        5      57      62
     PSU1 Hotspot Temp
                    not-available
                                        - C          0        5      90     100
     PSU2 Present
                    not-available
     PSU2 5V
                    not-available
                                        - mV         -        -       -       -
     PSU2 12V
                    not-available
                                        - mV         -        -       -       -
     PSU2 5V Curr
                    not-available
                                        - mA         -        -       -       -
     PSU2 12V Curr
                    not-available
                                        - mA         -        -       -       -
     PSU2 Fan 1
                    not-available
                                        - RPM        -        -       -       -
     PSU2 Fan 2
                    not-available
                                        - RPM        -        -       -       -
     PSU2 Inlet Temp
                    not-available
                                        - C          0        5      57      62
     PSU2 Hotspot Temp
                    not-available
                                        - C          0        5      90     100
     PSU_FAN
                    not-available
     Module B Expander Temp
                           failed
                                        - C          0        5      80      90
     Module A Expander Temp
                           failed
                                        - C          0        5      80      90
     Midplane 4 Temp       failed
                                        - C          0        5      55      60
     Midplane 3 Temp       failed
                                        - C          0        5      55      60
     Midplane 2 Temp       failed
                                        - C          0        5      55      60
     Midplane 1 Temp       failed
                                        - C          0        5      55      60
     Ambient Temp          failed
                                        - C          0        5      47      52
New to NetApp?
