NetApp Stage KB
Power supply cannot detect power off correctly
1
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS2720
  • FAS2750
  • ONTAP 9
Issue
  • When PSU1 is turned off, "environment sensors" is detected "PSU_OFF"correctly, but PSU2 cannot be detected even when PSU2 is turned off.
  • PSU1 power off
Example:
Cluster::> system node environment sensors show -type fru
Node Sensor                 State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
node-01
     PSU2 FRU              normal
                                         GOOD
     PSU1 FRU               fault
                                      PSU_OFF
node-02
     PSU2 FRU              normal
                                         GOOD
     PSU1 FRU               fault
                                      PSU_OFF
4 entries were displayed.
  • PSU2 power off
Example:
node-01
     PSU2 FRU              normal
                                         GOOD
     PSU1 FRU              normal
                                         GOOD
node-02
     PSU2 FRU              normal
                                         GOOD
     PSU1 FRU              normal
                                         GOOD
  • After PSU swap, PSU2 is detected correctly when it turned off, but PSU1 is not detected even when it is turned off.
  • PSU1 power off
Example:
Cluster::> system environment sensors show -type fru
node-01
     PSU2 FRU              normal
                                         GOOD
     PSU1 FRU              normal
                                         GOOD
node-02
     PSU2 FRU              normal
                                         GOOD
     PSU1 FRU              normal
                                         GOOD
  • PSU2 power off
Example:
node-01
     PSU2 FRU               fault
                                      PSU_OFF
     PSU1 FRU              normal
                                         GOOD
node-02
     PSU2 FRU               fault
                                      PSU_OFF
     PSU1 FRU              normal
                                         GOOD
New to NetApp?
