NetApp Stage KB
On system reboot, node is reporting "Disk auto-partitioning is disabled on this system: ADP DISABLED."
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • FAS8200
  • FAS8300
  • AFF A300
  • AFF A400
  • ADPv1
  • SSD and HDD mix configuration in same aggregate
Issue
  • On every node reboot, system reports ADP DISABLED and also generates an Autosupport with the event, even if the system is configured with ADP.
Mar 03 11:05:00 [Node-A:raid.autoPart.disabled:ALERT]: Disk auto-partitioning is disabled on this system: the system needs a minimum of 8 usable internal hard disks.
Mar 03 11:05:00 [Node-A:callhome.raid.adp.disabled:ALERT]: Disk auto-partitioning is disabled on this system: ADP DISABLED.
  • SYSCONFIG-R shows raid group layout do not changed:
Aggregate XXXXXXXX (online, raid_dp, fast zeroed, hybrid) (block checksums)
  Plex /XXXXXXXX/plex0 (online, normal, active, pool0)
    RAID group /XXXXXXXX/plex0/rg0 (normal, block checksums)
      RAID Disk    Device      HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity     0d.02.6     0d    2   6   SA:B   0  FSAS  7200 3807816/7798408704 3815447/7814037168 (fast zeroed)
      parity      0a.02.7     0a    2   7   SA:A   0  FSAS  7200 3807816/7798408704 3815447/7814037168 (fast zeroed)
      data        0d.02.8     0d    2   8   SA:B   0  FSAS  7200 3807816/7798408704 3815447/7814037168 (fast zeroed)
      data        0a.02.9     0a    2   9   SA:A   0  FSAS  7200 3807816/7798408704 3815447/7814037168 (fast zeroed)
      data        0d.02.10    0d    2   10  SA:B   0  FSAS  7200 3807816/7798408704 3815447/7814037168 (fast zeroed)
      data        0d.03.2     0d    3   2   SA:B   0  FSAS  7200 3807816/7798408704 3815447/7814037168 (fast zeroed)
    RAID group /XXXXXXXX/plex0/rg2 (normal, block checksums)
      dparity     0c.10.3P1    0c    10  3   SA:A   0   SSD   N/A 228853/468690944  228861/468707328 (fast zeroed)
      parity      0b.10.2P1    0b    10  2   SA:B   0   SSD   N/A 228853/468690944  228861/468707328 (fast zeroed)
      data        0c.10.15P1    0c    10  15  SA:A   0   SSD   N/A 228853/468690944  228861/468707328 (fast zeroed)
      data        0c.10.5P1    0c    10  5   SA:A   0   SSD   N/A 228853/468690944  228861/468707328 (fast zeroed)
      data        0b.10.8P1    0b    10  8   SA:B   0   SSD   N/A 228853/468690944  228861/468707328 (fast zeroed)
      data        0c.10.7P1    0c    10  7   SA:A   0   SSD   N/A 228853/468690944  228861/468707328 (fast zeroed)
New to NetApp?
