NetApp Stage KB
Node unresponsive after onsite power maintenance
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • Data ONTAP 8.2.3P3 7-Mode
  • FAS2520
Issue
  • Node down and unable to boot after onsite power maintenance.
  • Unable to ping or SSH access the SP of the affected node.
  • Console connection to the node not working
  • .No lights seen on the back of the Node impacted.
  • Power supply reports critical status in environment outputs
Power Supplies:
Element Status Status Bytes Status Descriptions
1: CRITICAL 02,00,04,F3 DC UNDER VOLTAGE, DC FAIL, AC FAIL, OFF, RQSTED ON, FAIL
2: OK 01,00,00,A0 RQSTED ON
  • Motherboard and Power Supply re-seat does not solve the issue
New to NetApp?
