NetApp Stage KB
Node reboots with BATTERY remain capacity critical low alert
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • AFF A50, AFF A30, AFF A20
  • AFF C60, AFF C30
  • ASA A50, ASA A30, ASA A20
  • ASA C30
  • FAS50
Issue
  • The following battery alerts are reported in the event logs. Example:
[Node-01: env_mgr: nvmem.battery.capLow:alert]: The NVMEM battery capacity is low (1 cycles).
[Node-01: env_mgr: nvmem.battery.fccLowCrit:EMERGENCY]: The NVMEM battery full-charge capacity is critically low (15 ). To prevent data loss, the system will shut down in 20 minutes.
[Node-01: env_mgr: callhome.battery.warning:alert]: Call home for BATTERY (remain capacity critical low) WARNING.
[Node-01: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (full capacity critical low) CRITICAL.
[Node-01: statd: monitor.nvramLowBattery:EMERGENCY]: NVRAM battery is dangerously low.
[Node-01: statd: monitor.nvramLowBattery.notice:notice]: If the NVRAM battery is dangerously low, the system shuts down automatically every 24 hours to encourage you to replace it. If you reboot the system it will run for another 24 hours before shutting down.
[Node-01: statd: callhome.battery.low:alert]: Call home for BATTERY_LOW.
[Node-01: statd: monitor.shutdown.nvramLowBattery.pending:alert]: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
  • If no actions are taken, the node reboots every 24 hours, and the following events are seen. Example:
[Node-01: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (BATTERY (full capacity critical low) for 20 mins)
[Node-01: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
  • During ONTAP boot following error may reported. Example:
WARNING:  The battery is experiencing a critical failure:
           - Battery full charge capacity is too low
           Without a working battery, the system cannot retain data
           during a power outage, which can result in data loss.
           Power down the system and verify that the battery is
           properly installed.
           To ignore this failure and boot the system in a mode
           where data loss might occur, press 'c' followed by 'Enter'
  • The sensors in the SP-LATEST-IPMI section of the AutoSupport report the following. Example:
hsamcmd --fault-show-all
tag  origin  fld                                     fault reason                                    count  time
1    bmc     /chassis-1/controller-a/nvbatt-1        Bat_Rem_Cap: Current Sensor 94 LNC              1      Sat Jul 19 23:25:29 2025
2    bmc     /chassis-1/controller-a/nvbatt-1        Bat_Rem_Cap: Current Sensor 94 LCR              1      Sat Jul 19 23:25:29 2025
3    bmc     /chassis-1/controller-a/nvbatt-1        Bat_Full_Cap: Current Sensor 95 LNC             1      Sat Jul 19 23:25:29 2025
4    bmc     /chassis-1/controller-a/nvbatt-1        Bat_Full_Cap: Current Sensor 95 LCR             1      Sat Jul 19 23:25:29 2025
5    bmc     /chassis-1/controller-a/nvbatt-1        Bat_Dstg_Cycles: Battery Sensor 99 Fault        2      Sat Jul 19 23:25:29 2025
Fault Lights On:
             /chassis-1        6
             /chassis-1/controller-a        6
             /chassis-1/controller-a/nvbatt-1                                                        6
Sensor Name              State          Current    Critical     Warning     Warning    Critical
                                        Reading       Low         Low         High       High
Bat Design Cap           normal         10500 W*hr     --          --          --          --
Bat Dstg Cycles          critlow            1 cycles    2 cycles    3 cycles   --          --
Bat Cycle Count          normal             3 cycles   --          --          --         450 cycles
Bat FRU LED                                OFF
Battery Charge Failed?                   FALSE
Battery Charge Bad?                       TRUE
Battery Capacity Message                   BAD
Battery RemCap Desc                      READY
NV0 Battery State                       FULLY_DISCHARGED
NV0 Battery Voltage      normal          8150 mV     5500 mV     5750 mV     8300 mV     8500 mV
Battery Charge                             BAD
Dblade Battery Status                   FULLY_DISCHARGED
Dblade Temp                             NORMAL_TEMP
  • The same errors appear even after power cycling the affected node.
Additional Information
  • After the BMC reboot, the BMC IP address will temporarily show 0.0.0.0 - this is expected behavior.  The condition will clear itself after 5-10 minutes.
  • More information at CFBMC-7408 - On some systems, the BMC IP address might temporarily show 0.0.0.0 after a BMC firmware update
New to NetApp?
