NetApp Stage KB
Node panic by battery failure
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
AFF-C190
Issue
  • Node panic.
  • events all reports env_mgr triggers OS halt.
Record 590: Sun May 21 16:25:51.590000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery temp critical
Record 591: Sun May 21 16:25:51.600000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery initial FCC f
Record 592: Sun May 21 16:25:58.000000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery voltage criti
Record 593: Sun May 21 16:25:58.930000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery current criti
Record 594: Sun May 21 16:25:58.940000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery charging curr
Record 595: Sun May 21 16:26:22.270000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery discharge FET
Record 596: Sun May 21 16:26:30.230000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery charging volt
Record 597: Sun May 21 16:26:30.240000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery charge FET fa
Record 598: Sun May 21 16:26:43.960000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery full capacity
Record 599: Sun May 21 16:26:47.110000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery remain capaci
Record 600: Sun May 21 16:28:30.230000 2023 [IPMI.emergency]: env_mgr triggers OS halt:Battery pack invalid
  • system sensors report battery is not readable.
Bat_Temp         | na         | degrees C  | na         | 0.000     | 5.000     | 56.000    | 60.000
Bat_Volt         | na         | Volts      | na         | 5.500     | 5.600     | 8.500     | 8.600
Bat_Curr         | na         | Amps       | na         | na        | na        | 1.520     | 1.800
Bat_Rem_Cap      | na         | Amps * hour | na         | na        | na        | na        | na
Bat_Full_Cap     | na         | Amps * hour | na         | na        | na        | na        | na
Bat_Charge_Curr  | na         | Amps       | na         | na        | na        | 2.400     | 2.900
Bat_Charge_Volt  | na         | Volts      | na         | na        | na        | 8.900     | 9.000
Bat_Design_Cap   | na         | Amps * hour | na         | na        | na        | na        | na
Bat_Initial_Fcc  | na         | Amps * hour | na         | na        | na        | na        | na
Bat_Average_Temp | na         | degrees C  | na         | na        | na        | na        | na
Bat_Rem_Cap_off  | na         | Amps * hour | na         | na        | na        | na        | na
Bat_Dstg_Cycles  | na         | cycles     | na         | 2.000     | 5.000     | na        | na
Bat_Power_Fault  | 0x0        | discrete   | Deasserted | na        | na        | na        | na
Bat_Dsg_FET_Flt  | na         | discrete   | na         | na        | na        | na        | na
Bat_Chg_FET_Flt  | na         | discrete   | na         | na        | na        | na        | na
Bat_Pack_Invalid | na         | discrete   | na         | na        | na        | na        | na
Bat_Cycle_Cnt    | na         | cycles     | na         | na        | na        | na        | na
Bat_Lrn_Active   | na         | discrete   | na         | na        | na        | na        | na
New to NetApp?
