NetApp Stage KB
Node boots to maintenance mode when running boot_ontap
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • Data ONTAP 8
Issue
  • When running boot_ontap from the LOADER prompt the node always boots into maintenance mode.
  • The following message is displayed:
NOTE: You have chosen to boot the diagnostics kernel.
The system has booted in maintenance mode allowing the
Use the 'sldiag' command in order to run diagnostics on the system.
New to NetApp?
