NetApp Stage KB
NVRAM Battery Low Alert on FAS8300/FAS8700/AFF A400 system
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • AFF A400
  • FAS8300
  • FAS8700
  • ONTAP Releases
    • ONTAP 9.16.1 and all later releases
    • ONTAP 9.15.1P5 and later
    • ONTAP 9.14.1P10 and later
    • ONTAP 9.13.1P13 and later
    • ONTAP 9.12.1P16 and later
  • BMC 13.11P1 and later
Issue
  • EMS-LOG-FILE shows:
ALERT monitor.shutdown.nvramLowBattery.pending: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
ALERT callhome.battery.low: Call home for BATTERY_LOW.
EMERGENCY monitor.nvramLowBattery: NVRAM battery is dangerously low.
ERROR nvmem.battery.capLowWarn: The NVMEM battery capacity is below normal (4 cycles).
ALERT monitor.shutdown.nvramLowBattery.pending:  NVRAM battery is dangerously low. Halting system in 23 hours. Replace the battery immediately!
  • NVMEM battery capacity is below normal:
::*> system node environment sensors show -name "Bat Curr"|"Bat Dstg Cycles"
Node Sensor                 State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
Node01
     Bat Curr              normal
                                        0 mA         -        -    1225    1475
     Bat Dstg Cycles       warn-low
                                        4 cycles     2        5       -       -
Node02
     Bat Curr              normal
                                        0 mA         -        -    1225    1475
     Bat Dstg Cycles       normal
                                       14 cycles     2        5       -       -
  • SP-LATEST-STATISTICS shows the drop in relative charge:
=-=-=-=-=-= Tue Jul 08, 2025 00:27:02 +0530  SP-LATEST-STATISTICS 1 line
    RelativeCharge    : 21 %
=-=-=-=-=-= Tue Jul 08, 2025 13:13:18 +0530  SP-LATEST-STATISTICS 1 line
=-=-=-=-=-= Wed Jul 09, 2025 00:17:03 +0530  SP-LATEST-STATISTICS 1 line
    RelativeCharge    : 19 %
=-=-=-=-=-= Wed Jul 09, 2025 13:13:18 +0530  SP-LATEST-STATISTICS 1 line
=-=-=-=-=-= Thu Jul 10, 2025 00:37:04 +0530  SP-LATEST-STATISTICS 1 line
    RelativeCharge    : 18 %
=-=-=-=-=-= Thu Jul 10, 2025 13:13:18 +0530  SP-LATEST-STATISTICS 1 line
New to NetApp?
