NetApp Stage KB
Multiple fan failure causes system shutdown
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS2552
  • ONTAP 9
  • Data ONTAP 8
Issue
System raises a fan failure message and causes a shutdown.
  • EMS log:
Jul 16 23:22:58 [node-1:callhome.shlf.fan:EMERGENCY]: Call home for SHELF COOLING UNIT FAILED
Jul 16 23:23:07 [node-1:monitor.fan.critical:EMERGENCY]: 2 fans have failed. Replace them to avoid overheating. If not corrected, system will shutdown in 2 minutes.
Jul 16 23:23:37 [node-1:callhome.fans.failed:EMERGENCY]: Call home for MULTIPLE FAN FAILURE
Jul 16 23:25:27 [node-1:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple fans failed)
  • AC_Power_Fail Asserted and Deasserted errors are reported repeatedly on Service Processor(SP) events all log:
Record 2043: Sat Jul 17 08:03:44 2021 [IPMI Event.critical]: IPMI SEL log limit exceeded
Record 2044: Sat Jul 17 08:03:44 2021 [IPMI.notice]: fc07 | 02 | EVT: 0300ffff | AC_Power_Fail | Assertion Event, "State Deasserted"
Record 2045: Sat Jul 17 08:03:48 2021 [SP.warning]: Agent IIRQ false alarm
Record 2046: Sat Jul 17 08:04:06 2021 [IPMI Event.critical]: IPMI SEL log limit exceeded
Record 2047: Sat Jul 17 08:04:06 2021 [IPMI.notice]: fd07 | 02 | EVT: 0301ffff | AC_Power_Fail | Assertion Event, "State Asserted"
Record 2048: Sat Jul 17 08:04:08 2021 [IPMI Event.critical]: IPMI SEL log limit exceeded
Record 2049: Sat Jul 17 08:04:08 2021 [IPMI.notice]: fe07 | 02 | EVT: 0300ffff | AC_Power_Fail | Assertion Event, "State Deasserted"
Record 2050: Sat Jul 17 08:04:09 2021 [IPMI Event.critical]: IPMI SEL log limit exceeded
Record 2051: Sat Jul 17 08:04:09 2021 [IPMI.notice]: ff07 | 02 | EVT: 0301ffff | AC_Power_Fail | Assertion Event, "State Asserted"
  • CPU related information cannot be read from SP system sensors output:
Sensor Name      | Current    | Unit       | Status     | LCR       | LNC       | UNC       | UCR
CPU0_Temp_Margin | na         | degrees C  | na         | na        | na        | -5.000    | 0.000
In_Flow_Temp     | 24.000     | degrees C  | ok         | 0.000     | 10.000    | 70.000    | 75.000
Out_Flow_Temp    | 23.000     | degrees C  | ok         | 0.000     | 10.000    | 82.000    | 87.000
Memory_Hot       | 0x0        | discrete   | Deasserted | na        | na        | na        | na
CPU_Hot          | 0x0        | discrete   | Deasserted | na        | na        | na        | na
CPU_Cat_Error    | 0x0        | discrete   | Deasserted | na        | na        | na        | na
CPU_Therm_Trip   | 0x0        | discrete   | Deasserted | na        | na        | na        | na
CPU_VCC          | na         | Volts      | na         | 0.708     | 0.747     | 1.348     | 1.426
CPU_1.05V        | na         | Volts      | na         | 0.892     | 0.941     | 1.154     | 1.203
CPU_VTT          | na         | Volts      | na         | 0.931     | 0.989     | 1.213     | 1.261
LM56_Temp        | na         | degrees C  | na         | 0.000     | 10.000    | 79.000    | 84.000
CPU_1.5V         | na         | Volts      | na         | 1.271     | 1.348     | 1.649     | 1.727
1G_1.0V          | na         | Volts      | na         | 0.854     | 0.902     | 1.096     | 1.154
FC_0.9V          | na         | Volts      | na         | 0.776     | 0.815     | 0.989     | 1.038
FC_1.0V          | na         | Volts      | na         | 0.854     | 0.902     | 1.096     | 1.154
USB_5.0V         | na         | Volts      | na         | 4.253     | 4.495     | 5.492     | 5.759
PCH_3.3V         | na         | Volts      | na         | 2.798     | 2.973     | 3.625     | 3.800
SASS_1.0V        | na         | Volts      | na         | 0.854     | 0.902     | 1.096     | 1.145
SASS_1.2V        | na         | Volts      | na         | 1.018     | 1.077     | 1.319     | 1.377
IB_1.2V          | na         | Volts      | na         | 1.018     | 1.077     | 1.319     | 1.37
New to NetApp?
