NetApp Stage KB
Multi disk failure PANIC during partner node's parts replacement
1
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS27x0
  • ONTAP 9
  • Advanced Disk Partitioning (ADP)
Issue
  • During partner node parts replacement, remove PCM from chassis, at that time partner takeover node occurred Multi Disk Panic.
EMS log:
PANIC: aggr pro_aggr01: raid volfsm, fatal multi-disk error. raid type raid_dp
Group name plex0/rg0 state NORMAL 3 disks failed in the group.
Disk 0b.00.0P1 Shelf 0 Bay 0 [NETAPP   X343_STBTE1T8A10 NA02] S/N [XXXXXXXXXX001] UID [6000C500:XXXXXXXX:500A0981:00000001:00000000:00000000:00000000:00000000:00000000:00000000] error disk does not exist.
Disk 0b.00.1P1 Shelf 0 Bay 1 [NETAPP   X343_STBTE1T8A10 NA02] S/N [XXXXXXXXXX001] UID [6000C500:XXXXXXXX:500A0981:00000001:00000000:00000000:00000000:00000000:00000000:00000000] error disk does not exist.
Disk 0b.00.3P1 Shelf 0 Bay 3 [NETAPP   X343_STBTE1T8A10 NA02] S/N [XXXXXXXXXX001] UID [6000C500:XXXXXXXX:500A0981:00000001:00000000:00000000:00000000:00000000:00000000:00000000] error disk does not exist. in SK process config_thread on release 9.4P4 (C) on Tue Jul 12 16:43:52 JST 2022
version: 9.4P4: Thu Nov  1 11:20:54 EDT 2018
  • After Panic, a node is booting up but is missing 3 disks and aggregate is failed/offline status.
sysconfig -r:
Aggregate pro_aggr01 (failed, raid_dp, partial) (block checksums)
  Plex /pro_aggr01/plex0 (offline, failed, inactive)
    RAID group /pro_aggr01/plex0/rg0 (partial, block checksums)
      RAID Disk Device   HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity FAILED    N/A                        1689530/ -
      data     0b.00.2P1 0b    0   2   SA:B   0   SAS 10000 1689530/3460157952 1689538/3460174336
      data FAILED    N/A                        1689530/ -
      data     0b.00.4P1 0b    0   4   SA:B   0   SAS 10000 1689530/3460157952 1689538/3460174336
      data     0b.00.5P1 0b    0   5   SA:B   0   SAS 10000 1689530/3460157952 1689538/3460174336
      data     0b.00.11P1 0b    0   11  SA:B   0   SAS 10000 1689530/3460157952 1689538/3460174336
      data     0b.00.7P1 0b    0   7   SA:B   0   SAS 10000 1689530/3460157952 1689538/3460174336
      data     0b.00.8P1 0b    0   8   SA:B   0   SAS 10000 1689530/3460157952 1689538/3460174336
      data     0b.00.9P1 0b    0   9   SA:B   0   SAS 10000 1689530/3460157952 1689538/3460174336
      data     0b.00.10P1 0b    0   10  SA:B   0   SAS 10000 1689530/3460157952 1689538/3460174336
      Raid group is missing 3 disks.
New to NetApp?
