NetApp Stage KB
Input Power Monitor Unrecoverable
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • ASA A150
Issue
  • The system reports a shelf fault in EMS-LOG-FILE.GZ
Node-01: monitor: monitor.globalStatus.critical:EMERGENCY: Disk shelf fault.
Node-01: statd: monitor.shelf.warning:error: Fault reported on disk storage shelf attached to channel 0b. Check fans, power supplies, disks, and temperature sensors.
Node-01: statd: callhome.shlf.fault:error: Call home for SHELF_FAULT
  • System reports an unrecoverable storage fault STORAGE SHOW FAULT -V
Node: Node-01
Enclosure Status: unrecoverable
Channel: 0b
Shelf: 0
Shelf Type: DS224-12
Product Serial Number: xxxxxxxx
Module Type: IOM12E
Input Power Monitor:
Element Status         Status Bytes  Status Descriptions
  1: UNRECOVERABLE     04,00,00,00
  2: UNRECOVERABLE     04,00,00,00
  • Attempting to read the sensor values with commands fails to generate output from both nodes
Cluster::*> system node run -node Node-01 -command sasadmin expander_cli 0a.0 psmi_read_input_power
sasadmin expander_cli: Failed SAS CLI command: psmi_read_input_power.
sasadmin expander_cli: failed.
Cluster::*> system node run -node Node-01 -command sasadmin expander_cli 0a.0 'ses_report_page 2'
sasadmin expander_cli: Failed SAS CLI command: ses_report_page 2.
Cluster::*> system node run -node Node-02 -command sasadmin expander_cli 0a.0 psmi_read_input_power
Cluster::*> system node run -node Node-02 -command sasadmin expander_cli 0a.0 'ses_report_page 2'
  • Rebooting the SP does not recover the input power monitor output
New to NetApp?
