Incrementing frame length errors on port interface Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:Visibility:PublicVotes:0Category:ontap-9Specialty:nasLast Updated: Applies to All ONTAP versions All FAS/AFF platforms Issue Frame Length errors: incrementing by 1 every 5 minutes No other errors are being recorded and all protocols are functioning correctly.
