NetApp Stage KB
How to obtain TruFOS Certificate for Brocade switches
2
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
brocade
Last Updated:
Applies to
Brocade Switches
  • The TruFOS license is linked to the support contract.
  • The TruFOS certificate when generated will run through to the end of the active support contract.
  • license --show  output confirms if an TruFOS certificate is expired.
/fabos/link_sbin/license --show:
  License Id : 10:00:xx:xx:xx:xx:xx:xx
  License 1 :
    License serial number   : FOS-86-0-04-11xxxx54
    License features        : Trusted FOS (TruFOS) Certificate
    Generation date         : 12/07/2022
    Expiry date             : 01/06/2023
    License has expired
  • Upgrading to latest version fail when the TruFOS certificate is not installed and can be verified by the above command license --show
ERROR: TruFOS validation failed. Please install a valid TruFOS and run firmwaredownload again
  • These licenses are generated from the Broadcom portal for the respective serial number.
  • Brocade TruFOS Certificates are required on the following platforms, starting with Fabric OS v9.1.0:
    • Brocade Gen 6 Directors
    • Brocade Gen 7 Directors
    • Brocade Gen 6 G630 (switch types 173 and 184)
    • Brocade Gen 7 G730 Switches
  • Brocade TruFOS Certificates are required on the following platforms, starting with Fabric OS v9.2.0:
    • G720
    • 7850
    • G620
    • G610
    • 7810
New to NetApp?
