NetApp Stage KB
How to determine 1600W PSU power efficiency
Visibility:
Votes:
0
Category:
not set
Specialty:
HW
Last Updated:
Applies to
  • AFF A800, AFF A400, AFF A250
  • AFF C800, AFF C400, AFF C250
  • ASA A800, ASA A400, ASA A250
  • ASA C800, ASA C400, ASA C250
  • FAS8700, FAS8300
  • NS224 storage shelf
  • E-Series EF600, EF300
  • 80 PLUS® Platinum 1600W PSU
  • 80 PLUS® Titanium 1600W PSU
This KB article helps you determine the correct part to order when replacing a 1600-Watt  power supply unit (PSU) in some NetApp products:
  • Current 1600-Watt (W) PSUs of NetApp AFF, ASA, FAS and E-Series storage systems are certified at 80 PLUS Platinum efficiency
  • Effective 2024-01-01, Commission Regulation (EU) 2019/424 requires power supplies for certain classes of storage equipment to meet the 80 PLUS Titanium efficiency requirement
  • NetApp 80 PLUS Titanium 1600W PSUs are now available
  • NetApp leverages multiple suppliers for a given Mfg. part number and power efficiency
Currently available PSU options:
Part Number
Part Description
Mfg. Part Number
Vendor + Model
80 PLUS Efficiency
X737A
X736A
PSU,AFF A700s,A800,EF600,EF300
PSU,AFF A700s,A800,A320
114-00208
Delta DPS-1600AB-18
LITEON PS-2162-8F
Platinum
X97602A
Power Supply,1600W,Titanium
114-00217
Delta TDPS-1600GB
QCS DCJ16002-06
Titanium
IMPORTANT: Intermixing PSUs with different efficiencies in the same chassis is not supported. When replacing a PSU, the correct part must be used or damage to the system might occur.
New to NetApp?
