NetApp Stage KB
HBA card X2071A not detected after Motherboard replacement
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • FAS/AFF systems.
  • ONTAP 9
  • HBA Card X2071A
Issue
  • After MB replacement,  unable to give back due to missing file system disks on the partner node.
[Node-1: svc_queue_thread: cf.disk.invent.mismatchalt:debug]: Status of some of the disks has changed or the node (Node-2) is missing 147 disks (detailed logs have been throttled).
  • Further checking the sasadmin expander_map output from maintenance mode shows slot X connection is missing on the newly replaced motherboard.
  • Reseating the card also results in the same error.
New to NetApp?
