NetApp Stage KB
Fault LED(s) ON with no actual issues
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
All AFF/FAS
Issue
  • Attention LED is ON, even though there is no actual issue(s).
  • In some scenarios the LED was ON due to a faulty component and remains ON after fixing it.
::> system health alert show
This table is currently empty.
::> system health status show
Status
ok
::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
  • FRU LED status command indicates LED status is ON. Examples
    • ONTAP OS 7-Mode
node*> fru_led status
Controller slot A: On (lit by Data ONTAP)
DIMM slot 1:       Off
DIMM slot 2:       Off
DIMM slot 3:       Off
DIMM-NV slot 1:    Off
PCI slot 1:        On
PCI slot 2:        Off
  • ONTAP OS Cluster Mode:
::*> system controller fru led show
Node                  FRU Type    Bay Slot State   Lit By
node_name
                      controller    A 1    on      SP
                      ioxm          B 1    off     -
                      pci           - 1    off     -
New to NetApp?
