Disk fault LED keeps coming on Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:Visibility:PublicVotes:0Category:aff-seriesSpecialty:HWLast Updated: Applies to AFF-A800/C800, AFF-A250/C250 NVMe internal shelf Issue Disk fault LED is still lit even after failed disk has been replaced Issuing the LED off command turns it off for a period of time but it comes back on
