NetApp Stage KB
Controller temperature sensor MemoryX_Hot is reporting Asserted
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • ONTAP 9
  • AFF Systems
  • FAS Systems
Issue
  • Controller fault LED is on
  • Sensor from the SP-LATEST-IPMI logs report as Asserted
    • Memory_Hot
    • Memory0_Hot
    •  Memory1_Hot
/usr/local/bin/ipmi sensors
Sensor Name      | Current    | Unit       | Status     | LCR       | LNC       | UNC       | UCR
Memory0_Hot      | 0x0        | discrete   | Deasserted | na        | na        | na        | na
CPU1_Error       | 0x0        | discrete   | Deasserted | na        | na        | na        | na
CPU1_Therm_Trip  | 0x0        | discrete   | Deasserted | na        | na        | na        | na
CPU1_Hot         | 0x0        | discrete   | Deasserted | na        | na        | na        | na
Memory1_Hot      | 0x0        | discrete   | Asserted   | na        | na        | na        | na
PCH_Hot          | 0x0        | discrete   | Deasserted | na        | na        | na        | na
HSAM OS(0x5):cmd(1) FLD(controller-b):fault(Temperature Sensor 9 Fault)
hsamcmd --fault-show-all
tag  origin  fld                                     fault reason                                    count  time
2    0x5     /chassis-1/controller-b                 Temperature Sensor 9 Fault                      1
::> system environment sensors show -state !normal
Node Sensor State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
node1
Memory1 Hot  fault HOT
  • SP-reboot does not clear this sensor status
New to NetApp?
