NetApp Stage KB
Call home for BATTERY (capacity low) CRITICAL
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • Service Processor (SP)
  • AFF Systems
  • FAS Systems
Issue
  • EMS reports "BATTERY (capacity low) CRITICAL".
Example:
[NodeA:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
  • Check system sensors show in SP, the status of battery is normal.
Example:
Bat_Status       | 0x0        | discrete   | Ready      | na        | na        | na        | na
Bat_Ambient_1    | 25.000     | degrees C  | ok         | 0.000     | 3.000     | 47.000    | 52.000
Bat_Ambient_2    | 25.000     | degrees C  | ok         | 0.000     | 3.000     | 47.000    | 52.000
Bat_Charge_Curr  | 0.000      | Amps       | ok         | na        | na        | 5.500     | 6.000
Bat_Charge_Volt  | 8.150      | Volts      | ok         | na        | na        | 8.350     | 8.400
Bat_Curr         | 0.000      | Amps       | ok         | -0.100    | -0.050    | 2.500     | 3.000
Bat_Cycle_Count  | 12.000     | cycles     | ok         | na        | na        | na        | na
Bat_Design_Cap   | 4.300      | Amps*hour  | ok         | 0.000     | 0.000     | 6.375     | 6.375
Bat_Dstg_Cycles  | 12.000     | cycles     | ok         | 2.000     | 5.000     | na        | na
Bat_Full_Cap     | 3.025      | Amps*hour  | ok         | 2.000     | 2.200     | 4.750     | 5.000
Bat_Initial_Fcc  | 3.275      | Amps*hour  | ok         | 2.000     | 2.200     | 4.750     | 5.000
Bat_Rem_Cap      | 3.025      | Amps*hour  | ok         | 0.250     | 0.500     | 4.750     | 5.000
Bat_Temp         | 24.000     | degrees C  | ok         | -5.000    | 0.000     | 55.000    | 60.000
Bat_Volt         | 8.150      | Volts      | ok         | 6.000     | 6.500     | 8.300     | 8.500
  • "Learn cycle" is recorded in "events all" of SP.
Example:
Record 1552: Mon Feb 22 00:21:19.602467 2021 [IPMI.notice]: 7d04 | 02 | EVT: 6f08ffff | Bat_Status | Assertion Event, "Learn Cycle"
Record 1553: Mon Feb 22 01:31:20.286318 2021 [IPMI.notice]: 7e04 | 02 | EVT: ef08ffff | Bat_Status | Deassertion Event, "Learn Cycle"
  • EMS reports "nvram.battery.current.normal"
Example:
[?] Thu Sep 02 06:17:01 UTC [NodeA: env_mgr: nvram.battery.current.normal:info]: The NVRAM battery current is normal.
New to NetApp?
