NetApp Stage KB
Call home for BATTERY_LOW on a FAS2650
1
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS2650
  • FAS2620
Issue
EMS also sends a 24 hrs callhome notice but it fails over in 20 min due to critical state
EMS log reports the following error
[cluster-01: env_mgr: nvmem.battery.capLowCrit:EMERGENCY]: The NVMEM battery capacity is critically low (0 cycles). To prevent data loss, the system will shut down in 20 minutes.
[cluster-01: env_mgr: nvmem.battery.fccLowCrit:EMERGENCY]: The NVMEM battery full-charge capacity is critically low (0 ). To prevent data loss, the system will shut down in 20 minutes.
[cluster-01: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
[cluster-01: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (full charge capacity low) CRITICAL.
[cluster-01: statd: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery remain capacity critical)
New to NetApp?
