NetApp Stage KB
CHASSIS FAN FRU Failed reported by 1 node
Visibility:
Votes:
0
Category:
aff-series
Specialty:
HW
Last Updated:
Applies to
  • FAS8200
  • AFF A300
  • ONTAP 9
Issue
  • One of the nodes reports Chassis Fan FRU failed
callhome.c.fan.fru.fault: Call home for CHASSIS FAN FRU FAILED: SysFan1 F1
callhome.c.fan.fru.fault: Call home for CHASSIS FAN FRU FAILED: SysFan1 F2
  • Multiple errors and alerts reported in event log
Cluster::> event log show
Time                Node             Severity      Event
2/24/2025 02:19:58  Node B      ERROR         monitor.chassisFan.stop: Chassis fan contains at least one stopped fan: SysFan1 F2 (failed)
2/24/2025 02:19:58  Node B      ERROR         monitor.chassisFan.stop: Chassis fan contains at least one stopped fan: SysFan1 F1 (failed)
2/24/2025 02:00:00  Node B      ALERT         monitor.fan.failed: Multiple fans has failed: Sysfan1 F1, Sysfan1 F2.
2/24/2025 01:25:03  Node B      ALERT         callhome.hm.alert.critical: Call home for Health Monitor process cphm: CriticalFruMultiFaultAlert.
2/24/2025 01:24:47  Node B      ALERT         hm.alert.raised: Alert Id =CriticalFruMultiFaultAlert, Alerting Resource = xxxx raised by monitor chassis
2/24/2025 01:20:00  Node B      EMERGENCY     monitor.globalStatus.critical: Multiple fans has failed: Sysfan1 F1, Sysfan1 F2.
  • Output of system node environment sensors show reveals a fault for FAN1
Node Sensor                 State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
Node B
     Fan3                  normal
                                         GOOD
     Fan2                  normal
                                         GOOD
     Fan1                  fault
                                         MULTIFAULT
  • Node A correctly reports the fan FRU information in sysconfig -M but Node B shows an error
Node A
!FAN1!042142036602!!441-00025!A1!
!FAN2!021917019266!!441-00025!A1!
!FAN3!021917019271!!441-00025!A1!
Node B
!FAN1: Error reading FRU EEPROM
  • Fan FRU replaced but issue not resolved
New to NetApp?
