NetApp Stage KB
Both nodes rebooted abruptly due to system input power lost
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • AFF A300
  • ONTAP 9.x
Issue
  • Both nodes undergo simultaneous reboots.
  • After reboot, both nodes are able to start up successfully.
  • Other devices in the same rack do not have issues.
  • Both PSUs are connected to separate PDUs.
  • The problem still occurs even after proactively replacing the both motherboards.
  • Node console output shows that node reboots due to "Power Fail" error.
* Power Fail - Please Wait *
CPU cores enabled = 1
DIMM speed        = 2133.33 MHz
SATA (AHCI) Device: SV9MST6D120GLM41NP
Boot Loader version 6.0.17
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2023 NetApp, Inc. All Rights Reserved.
[monitor.globalStatus.critical:EMERGENCY]: Power Supply Status Critical: PSU1.
[monitor.globalStatus.critical:EMERGENCY]: Power Supply Status Critical: PSU2.
  • SYSTEM-EVENT-LOG show "system input power lost"
[SP.emergency]: System input power lost
  • SP-LATEST-IPMI log shows all PSU status are normal
Voltage Status                            GOOD
PSU2 Bad                                 FALSE
PSU1 Bad                                 FALSE
PSU2 need replacement                       NO
PSU1 need replacement                       NO
PSU2                                      GOOD
PSU1                                      GOOD
New to NetApp?
