NetApp Stage KB
BMC Firmware update progress stuck at 100percent after ONTAP upgrade
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS8300
  • ONTAP 9
  • Baseboard Management Controller (BMC)
Issue
  • After the automatic BMC upgrade triggered by ONTAP upgrade, the upgrade progress consistently stalls at 100%, whereas typically, after the upgrade is complete, the progress resets to 0.
Cluster::> system service-processor image update-progress show
                 In                           Percent
Node             Progress Start Time          Done    End Time
node-1         no       5/27/2025 11:36:37  100     5/27/2025 11:43:04
node-2         no       5/27/2025 11:09:05  0       5/27/2025 11:17:12
  • Rebooting the BMC doesn't change anything.
New to NetApp?
