NetApp Stage KB
Cluster join fails from system manager GUI
1
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
ONTAP 9.7
Issue
When join a new node in the existing cluster the error encounters:
"Node add Job failed: Failed to start cluster join on node: XX.XX.XX.XX: Unused cluster ports exist in the cluster. One or more ports may not be in the "healthy" state, or may be incorrectly assigned to the "Cluster" Ipspace. Run "network port show -ipspace Cluster" to view the cluster ports. Correct any issues, and then try the command again."
New to NetApp?
