NULL Piece exception following two drive failures in traditional volume group Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:2Visibility:PublicVotes:0Category:e-series-systemsSpecialty:esgLast Updated: Applies to SANtricity OS 11.70.3 (and likely others) Issue Multiple drive failures in RAID 6 VG led to NULL Piece exception.
