NetApp Stage KB
E-Series replacement controller locks down due to auto code synchronization failure
2
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • NetApp E-Series
  • E-Series platforms: E2800, E5700, E4000, EF300 and EF600
  • NetApp SANtricity 11.70.4 or newer
Issue
  • After replacing an E-Series controller, the replacement enters into a lock down state due to mismatched firmware.
  • The native (alternate) controller reports auto code synchronization (ACS) failure due to missing bundle metadata file. Error "/bundle/metadata.active/metadata doesn't exist" can be seen in the journal logs:
    • The journal logs can be retrieved from the diag shell using this command: sudo journalctl --since "2 days ago"
Dec 07 02:36:59 eos-b downloadmgr[]: [tid=42688] Received request -
Dec 07 02:36:59 eos-b acsDaemon[]: Spawning /usr/bin/sendImageCert -b root.active raid.active msw.active iom.active
Dec 07 02:36:59 eos-b acsDaemon[]: [tid=34816] Spawning /usr/bin/sendImageCert -b root.active raid.active msw.active iom.active
Dec 07 02:36:59 eos-b downloadmgr[]: [tid=42688] Runnable for ServerMessagingProtocol exiting
Dec 07 02:36:59 eos-b sendImageCert[]: [tid=23616] set stdErrLogging 0
Dec 07 02:36:59 eos-b sendImageCert[]: [tid=23616] isZeroMD5Supported: response = {"status":"success","source":"DownloadMgr_A"}
Dec 07 02:36:59 eos-b sendImageCert[]: [tid=23616] /bundle/metadata.active/metadata doesn't exist
  • The replacement controller reports ACS no valid Dom0Image found in the eos controller shell or the console logs available in diag (/var/log/eos-_eos_console.log)
12/12/25-23:28:17 (acsDriveImage): NOTE:  ACS Dom0 evaluate existing extents
12/12/25-23:28:17 (acsDriveImage): WARN:  ACS findImages - 5 extents found for Dom0 Image
12/12/25-23:28:17 (acsDriveImage): WARN:  ACS no valid Dom0Image found
12/12/25-23:28:17 (acsDriveImage): NOTE:  ACS Dom0 getCompleteImages - 0  images to evaluate
  • The replacement controller reports repeadetly ICON MsgQ Error!!! in the eos controller shell or the console logs available in diag (/var/log/eos-_eos_console.log) until the issue is resolved.
12/18/25-19:43:42 (SasIniWkr0): WARN:  ICON MsgQ Error!!!
12/18/25-19:44:43 (SasIniWkr0): WARN:  ICON MsgQ Error!!!
12/18/25-19:45:44 (SasIniWkr0): WARN:  ICON MsgQ Error!!!
12/18/25-19:46:45 (SasIniWkr0): WARN:  ICON MsgQ Error!!!
12/18/25-19:47:46 (SasIniWkr0): WARN:  ICON MsgQ Error!!!
12/18/25-19:48:47 (SasIniWkr0): WARN:  ICON MsgQ Error!!!
12/18/25-19:49:48 (SasIniWkr0): WARN:  ICON MsgQ Error!!!
New to NetApp?
