NetApp Stage KB
Does manually failing impending failure drive cause difference of data protection?
2
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
Applies to
  • E-Series
  • Drive is in Impending failure state with enough spare drives or preservation capacity
Answer
No. From the data protection perspective, there is no difference between the following methods:
  • Replace the drive after it is failed
Impending failure drive gets failed once its contents are copied to spare drives or preservation capacity, then these contents are copied back after the drive is replaced
  • Replace the drive after manually failing
After manually failing the Impending failure drive without copying data, reconstruction is performed
