StorageGRID diagnostics report Cassandra Request Timeouts
Applies to
NetApp StorageGRID
Issue
- Cassandra Request Timeouts in Diagnostics.
- The issue is observed post a network change activity performed on the cluster.
- Check the stability of connectivity between nodes by running the below command on Admin node:
for node in `grep storagegrid-gen-host /etc/hosts | awk '{print $2}'`;do echo -e "\n----------$node--------" && ssh $node 'nodetool describecluster';done - If every time this command is ran, difference in connectivity is observed between nodes, then customer needs to get the network team involved to get the issue resolved.
