Newly added StorageGRID node unable to connect with GRID Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:1Visibility:PublicVotes:0Category:storagegridSpecialty:sgridLast Updated: Applies to StorageGRID Issue During StorageGRID expansion, only the node’s BMC and LACP are accessible. The node itself is unreachable and cannot communicate with other GRID nodes.
