NetApp Stage KB
SnapCenter 6.0.1 Discovery fails with a timeout of 60 minutes
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
SNAPX
Last Updated:
Applies to
  • SnapCenter Creator Plug-in (SCC) 6.0.1
  • DB2 Database plug-in for SCC
Issue
After adding the DB2 Host with the DB2 Plug-in using sudoers setup, while running discovery, the following error message appears:
ErrorCode(-1), ErrorMessage (SCC-00175: Auto Complete Discovery for plug-in [DB2] failedwith error [       Operation [DISCOVERCOMPLETE] timed out, refer logs for more details.Set the SC_AGENT_TIMEOUT parameter for configuring the timeout on this host by running"Set-SmConfigSettings -Plugin -HostName hostname -PluginCode <plugin_code> -configSettings@{"SC_AGENT_TIMEOUT"="timeout_in_seconds"} " PowerShell cmdlet from the SnapCenter Server.] and exit code [1]. Exiting.)
Note: this issue may also present itself on other Plug-ins that do proper Discovery of Databases.
New to NetApp?
