NetApp Stage KB
Regenerated AIQUM HTTPS certificate is not reflected on cluster side
3
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • NetApp Active IQ Unified Manager (AIQUM)
  • ONTAP 9
Issue
  • Clicking Regenerate HTTPS Certificate in AIQUM WebUI does not stop event log in cluster side:
mgmtgwd.certificate.expiring: A digital certificate with Fully Qualified Domain Name (FQDN) <CERTIFICATE_NAME>, Serial Number <SERIAL>, Certificate Authority <UM> and type server-ca for Vserver <SVM> will expire in the next XX day(s)
Note:
  • AUDIT-MLOG-TXT.GZ shows the following messages:
<netapp version='1.0' xmlns='http://www.netapp.com/filer/admin' nmsdk_version='9.8P2' nmsdk_platform='Windows Server 2016' nmsdk_language='Java'><security-certificate-install><type>client</type><private-key>XXX</private-key><certificate>-----BEGIN CERTIFICATE-----^M [CERTIFICATE] :: Pending:
security-certificate-install :: Error: duplicate entry
<netapp version='1.0' xmlns='http://www.netapp.com/filer/admin' nmsdk_version='9.8P2' nmsdk_platform='Windows Server 2016' nmsdk_language='Java'><ems-event-notification-destination-modify-iter><attributes><event-notification-destination><rest-api-url>XXX</rest-api-url><certificate-authority>[UM-UUID]</certificate-authority><certificate-serial>[SERIAL]</certificate-serial></event-notification-destination></attributes><query><event-notification-destination><name>[DESTINATION]</name></event-notification-destination></query></ems-event-notification-destination-modify-iter></netapp>^M  :: Pending:
ems-event-notification-destination-modify-iter :: Success:
  • AUDIT-MLOG-TXT.GZ does not show security-certificate-delete and security-certificate-install that should be output following the above:
<netapp version='1.0' xmlns='http://www.netapp.com/filer/admin' nmsdk_version='9.8P2' nmsdk_platform='Windows Server 2016' nmsdk_language='Java'><security-certificate-delete><common-name>[COMMON-NAME]</common-name><type>server-ca</type><certificate-authority>[CA]</certificate-authority><vserver>[CLUSTER_NAME]</vserver><serial-number>[SERIAL]</serial-number></security-certificate-delete></netapp>^M  :: Pending:
security-certificate-delete :: Success:
<netapp version='1.0' xmlns='http://www.netapp.com/filer/admin' nmsdk_version='9.8P2' nmsdk_platform='Windows Server 2016' nmsdk_language='Java'><security-certificate-install><type>server-ca</type><certificate>-----BEGIN CERTIFICATE-----^M [CERTIFICATE]... :: Pending:
security-certificate-install :: Success:
New to NetApp?
