NetApp Stage KB
CONTAP-187943: RFE: add note to volume delete dialog to raise awareness about the called out capacity being logical
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
om
Last Updated:
Issue
  • This is a request for enhancement to add a note to the ONTAP System Manager GUI volume delete dialog.
  • The note should relate to the checkbox where the admin has to confirm the capacity to be deleted.
  • The goal is to raise awareness that the called out capacity is logical-capacity.
  • This is to prevent confusion if shown capacity is larger than volume physical-used capacity for example on volume clones or volumes with storage efficiency reduction against physical-used capacity.
New to NetApp?
