NetApp Stage KB
Write latency and low throughput in Metrocluster configurations
3
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • ONTAP 9
  • Metrocluster
Issue
  • High write latency on Metrocluster systems
  • Low number of IOPS can be seen than the expected IOPS
  • PerfArchives show high remote disk latency and back-to-back CPs do to long P2_FLUSH phase
  • From CLI, Check using command qos statistics volume latency show
Example:
cluster::> qos statistics volume latency show -node node1
Workload        ID    Latency    Network    Cluster       Data       Disk      QoS      NVRAM      Cloud
volume_1      12578     10ms      1ms        0ms         0.5us         1ms      0ms       9ms        0ms  volume_2       5232     2ms       1ms        0ms         0.25us        1ms      0ms      0ms        0ms  volume_3      17160     1ms       1ms        0ms         0.25us        1ms      0ms      0ms        0ms
The above example means that the volume_1 is impacted by NVLog Transfer latency
New to NetApp?
