NetApp Stage KB
Lower than expected performance while utilizing a single volume
2
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
Issue
  • Lower than expected performance while utilizing a single volume
  • Latency or slowness is seen in any operating system (Windows, Mac OS, Linux, ESX, etc.) or application (Office, Oracle, ESXi, Hyper-V, etc.)
  • There can be no performance issue reported and the CPU is still reaching above 90% frequently
  • High latency on a volume with low CPU utilization
    • Note: Lower end platforms may see CPU closer to 50% while higher end platforms may see CPU closer to 10-20%
Example:
  • the rebooting of virtual machine is slow.
  • All the file(Execl and Adobe etc.) accessing and application(IE, Edge etc) are slow.
  • The output of command  sysstat shows a low Avg CPU utilization
  • The output of wafltop only shows the high i/o on vol1
  • The output of qos statistics volume latency show only shows the high latency on vol1
  • vol1 takes the majority of Ops
  • No high latency from other volumes
CPU Utilization Percent
                                  Application      Total     STRIPE LAST_STRIPE STRIPEGROUP  VOL_LOG VOL_VBN_RANGE VBN_RANGE  VOL_VBN        VBN        VOL AGGR_VBN_RANGE AGGR_VBN     AGGR     SERIAL   XCleaner
aggr1:vol1:cifs:WAFL_SPINNP_WRITE:         54          0          0          0          0          0          0          0          0          0         29          0          0          0         14
aggr1:vol2:cifs:WAFL_SPINNP_WRITE:          2          2          0          0          0          0          0          0          0          0          0          0          0          0          0
aggr1:vol3:cifs:WAFL_SPINNP_WRITE:          1          1          0          0          0          0          0          0          0          0          0          0          0          0          0
aggr1:vol4:cifs:WAFL_SPINNP_WRITE:          1          1          0          0          0          0          0          0          0          0          0          0          0          0          0
I/O utilization
                                   ---------MB Read---------- ---------MB Write--------- --------IOs Read---------- --------IOs Write---------
                                   Application MB Total Standard ExtCache  Hybrid  Standard ExtCache  Hybrid  Standard ExtCache  Hybrid  Standard ExtCache  Hybrid
aggr1:vol1:cifs:WAFL_SPINNP_WRITE:        2558        9        0        0     2549        0        0        0        0        0     1287        0        0
aggr1:vol2:cifs:WAFL_SPINNP_WRITE:          12        0        0        0       12        0        0        0        0        0        3        0        0
aggr1:vol3:cifs:WAFL_SPINNP_WRITE:           7        0        0        0        7        0        0        0        0        0        1        0        0
aggr1:vol4:cifs:WAFL_SPINNP_WRITE:           5        0        0        0        5        0        0        0        0        0        1        0        0
Cluster::> node run -node node1 -command sysstat -x 1
 CPU    NFS   CIFS   HTTP   Total     Net   kB/s    Disk   kB/s    Tape   kB/s   Cache  Cache    CP           CP_Ty               CP_Ph       Disk   OTHER    FCP  iSCSI     FCP   kB/s   iSCSI   kB/s
                                       in    out    read  write    read  write     age    hit  time  [T--H--F--N--B--O--#--:]  [n--v--p--f]   util                            in    out      in    out
 13%    261      3      0    2927  222768 258592     104       0       0      0    12    100%    0%   0--0--0--0--0--0--0--0    0--0--0--0      1%    2663      0      0       0      0       0      0
 15%    403      6      0    3040  255451 255197     116       0       0      0    12    100%    0%   0--0--0--0--0--0--0--0    0--0--0--0      2%    2631      0      0       0      0       0      0
  5%    348     10      0     811    6094   9894     232      24       0      0    12    100%    0%   0--0--0--0--0--0--0--0    0--0--0--0      2%     453      0      0       0      0       0      0
Cluster::> qos statistics volume latency show -vserver SVM1 -volume Vol1
  Workload            ID    Latency    Network    Cluster       Data       Disk    QoS Max    QoS Min NVRAM      Cloud  FlexCache    SM Sync         VA
-total-              -     173.91ms   136.00us     0ms       170.98ms     437.00us   0ms       0ms    2.35ms       0ms        0ms        0ms        0ms
Vol1-widXXXXX   49458      206.66ms   125.00us     0ms       204.11ms     466.00us   0ms       0ms    1.96ms       0ms        0ms        0ms        0ms
New to NetApp?
