Increased latency after converting FlexVol to FlexGroup Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:1Visibility:PublicVotes:0Category:ontap-9Specialty:perfLast Updated: Applies to ONTAP 9 FlexGroup Issue A FlexVol volume is converted to a FlexGroup. Then a second member volume is added. Latency is higher on one constituent verses the other.
