NetApp Stage KB
How to identify full volume name from qos statistics output
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
  • Clustered Data ONTAP 8
  • ONTAP 9
This KB will help Performance TSE’s or Customers to see the full volume name while troubleshooting/monitoring Performance issues.
  • qos statistics volume latency/performance/workload show commands is used to see the performance on the volume/workload.
  • However, because of character limitations full volume/workload name does not show up.
In those scenarios run -showallfields command to view the full volume name.
  • One way is to identify the volume ID where high latency/throughput has been observed and then from ASUP in volume.xml section can search with volume/workload ID and then can identify the full volume name based on the volume ID.
  • But this would take time and not in every issues ASUP is available to help as Bank or Other secured Customers may disabled ASUP due to their business requirement.
New to NetApp?
