NetApp Stage KB
High latency seen when using volume move in foreground
Visibility:
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
Applies to
  • ONTAP 9
  • Volume move
Issue
  • Using the command volume move start with the parameter -foreground true.
  • Increased latency may be seen from Data (CPU D-Blade) and/or Disk from the command  qos statistics volume latency show.
  • Example: This output shows higher than usual Data latency or Disk latency from the command qos statistics volume latency show.
Cluster::> qos statistics volume latency show
Workload            ID    Latency    Network    Cluster       Data       Disk        QoS      NVRAM      Cloud
-total-              -     8.88ms     2.82ms     1.00us  1032.00us     5.02ms        0ms     2.00us        0ms
citrix_home1-..   6762   137.73ms     1.91ms     1.00us    22.93ms   112.89ms        0ms        0ms        0ms
New to NetApp?
