High CPU Alerts while running system controller replace Last updated Save as PDF Share Share Tweet Closure Action:Select an actionApprovedRejectedGuide Link:Select rejection reason:Select a reasonInsufficient informationExisting KB updatedExisting KB availableContent not requiredPlease let us know what is missing:Existing KB Link:Additional Comments:Set the Confidence and Visibility correctly on the Capture Manager.Link the KB article to the Case. If you fail to link, the PAR will be scored as Capture Loss for the case owner. Views:2Visibility:PublicVotes:0Category:ontap-9Specialty:perfLast Updated: Applies to ONTAP 9 Issue Alerts while starting “system controller replace” due to high CPU usage on the Cluster Nodes
